Western-Outbound
Date:  1-20-2019
Number of Hours:  0.30
Manual Reference:  AA-188
Brief Description:  AA-188 Lower Rudder Hinge Rivet Length
On December 4th 2018 Rans issued an Assembly Alert (AA-188) regarding the grip length of the four 3/16 stainless steel rivets (CCPQ-66) holding the lower rudder hinge to the vertical stabilizer. They sent out a replacement (CCPQ-68) to rectify this. They were received on January 16th 2019 but having already built this part I used a number #11 drill bit to carefully remove the heads of all four rivets, once they were off I wiggled the hinges clear and used a centre punch to push the rivet body inside the stabilizer. After inspection of the holes there was no damage found and the new rivets were installed.
Post install of NEW CCPQ-68
