Brief Description: Horizontal Stabiliser continued
Using a Micro stop and a countersink bit I drilled the countersinks into both sides of the spar at the centre section. I also using a solid rivet squeezer put the 120 Degree dimples for Pop Rivets into the skin and the nose ribs in the appropriate places. The skin was then applied with clecos and the flush rivets were pulled.
