Brief Description: Canopy, Panel details, wire clean up
Derek 8.0 Phil 8.0
David Clay came over at 9 before work to help us do some final adjustments to the canopy. Spent countless number of trips back and forth trimming a little off at a time with an abrasive disc.
Used David's special drill bit to drill holes through the canopy for attachement to the right side of the frame. David had to leave for work so we decided to wait until later to continue so we can get another set of hands and his experience.
Spent the rest of the day after lunch doing details getting ready for completion. drilled holes in inspection plates. Glued in aluminum reinforcement to the wheel pants. Cleaned up more wiring details. Installed seat belts. Epoxied switches in the panel for a straighter fit.
