Brief Description: Installed Transponder and Comm Radios
Derek 6.0 Phil 4.0
This past week, Derek had a D-sub end put on the encoder cable to plug into our Garmin GTX 327 Transponder. $65 dollars but knew it would be correct. Plugged in perfectly. Also installed MGL premade radio harness. Connected coax for both radios. Phil was able to open up the crates for his RV-7 that also arrived this week. We dropped the engine off at a buggy shop in Lorena with a mechanic so he could diagnose and repair the remaining leak coming from the rear seal area. Should be able to reinstall the motor next week. Seat foam is at the upholstry shop. We are waiting for some additional material to arrive this coming week.
