Phils Web Site
Date:  7-15-2012
Number of Hours:  12.00
Brief Description:  Installed Comm and Transponder Ant. Installed Tra
Derek 6.0 Phil 6.0
Installed the COMM and Transponder antenna under belly of the airplane. Came with paper templates made it so easy. Why doesn't everyone do that??
Installed the Outside Air Temperature Probe sticking out under the left horizontal stabilizer to shade it from direct sunlight and get a good ambiant temp reading
fabricated a transponder bracket to mount the transponder underneath the right side of the panel.
COMM and Xponder
COMM and Xponder
OAT probe mounted left rear fuselage under the HS
Garmin GTX Mounted under the panel
