Phils Web Site
Onex
Firewall
5-28-2012
Mounted Firewall Items
Derek 7.00 Phil 7.00
Mounted Coils to the firewall
Mounted RADAC to top of firewall
Mounted Master Solenoid below battery box to be closer to battery connections.
Used Stainless Steel waterbottle from HEB for an oil/air seperator. Fabricated a holding bracket out of aluminum and a radiator clamp.
Attached throttle quadrent on left side of cockpit. Routed Mixture cable and throttle cable through firewall near the oil/air seperator.
Used dremel tool to cut out front holes in the upper and lower cowlings
Onex Home
1057
Firewall
Inventory
RV-7 Home
