Phil 5.5 Derek 5.5. Detemined to be to wide of a gap on between the tail wheel angles F22-07R/L. Per Sonex, encased the tailspring with 4130 tube to increase overall diameter. Still used a couple of washers shown in picture 2 to final shore up the fit at the upper end of the tailspring. Hand drilled through the tailspar and doubler plate at EXACTLY 24.3 degrees (ha!) for the tailspring to exetend through (support at the rear)
Attached the elevator in place. Then attached the solid steering linkage from the caster to the steering plate at the bottom of the rudder. This is the same part that the rudder cables will attach to in order to control the rudder.
We then had the great pleasure of taking the Onex down off of it's saw horses and pushed her out of the next and down the driveway!!
