Removed the yoke and reversed the orientation of the block attached to the main spar. Inserted 2 small washers to remove the additional play (side to side) in the yoke control frame C03-03.
Riveted several "oops" rivets CCP-54s on the bottom of the wings where we had enlarged the holes due to having to drill out rivets to correct a wing alignment issue
About 10am we left to go help David Clay move his Sonex from his garage to the hangar at Temple Airport.
After that we had lunch and returned to start building the ailerons. See Photos.We were pleased that both ailerons turned out flat and twist- free.
