Brief Description: Closed up Tail Skin, Drilled Holes for Rudder Cabl
Derek 6 hrs Phil 6 hrs. Installed Grip on yoke. Cut holes in side of tail skin for rudder cables. Attached rudder cables to rudder control horn. Installed cotter pins in all castle nuts on tail wheel and rudder control horn. installed cotter pins on rudder piano hinge.
Worked on outboard wings. Drilled, deburred and installed bolts and screws for rib attachments (2 most inner ribs) Cut opening in the outboard root wing for clearance of aileron paddles. installed the support channel for the paddle.
