Phils Web Site
RV-7
HS
Using the brass barb in the hinge bearing, drilled right elevator horn to size 30....will upsize to 1/4" later. Also worked on fiberglass tip on right HS & elevator.
Also continued work with bondo on left HS.
Onex Home
RV-7 Home
600
195
Inventory
