After mounting the firewall and engine mount to the automovie stand, I was able to hang the engine. The discerning eye will note the engine seems to sit a bit nose low... it does. :( When building the frame to hang this engine, I forgot to take into account the 6 degree tilt the fuselage has which leaves the engine at the proper thrust angle. Fortunately for me, it does not matter in the least! :)
I then proceeded to install the engine cowling and can now complete all final adjustments and rivet the cowl together.
I also plan to start assembling or mocking up various bits of the FWF setup while I continue to work on the rest of the project.
