Peterson Bearhawk
Date:  2-28-2021
Number of Hours:  1.00
Brief Description:  Engine Cowling - Pt 16
Today I had been cleaning up the hanger and I did the "squirrel!" thing... instead of continuing with the upper nose cowl I decided to tackle the exit air dam located at the bottom of the engine cowling.
I did not really want to start sanding on the upper cowl as I did not have that much time so I decided to figure out how to make a pattern/mold so I could fabricate the air dam out of fiberglass.
I started by cutting some posterboard into a 3" length then cut 1" deep tabs down one side. I started to tape this into place inside the cowl with the 2" section hanging down outside the cowling but found I need to trim the corners to obtain a neater look as well as cut slits into this "outer" section to eliminate bowing.
After it started to look decent I covered the inside and outside with aluminum tape to stiffen up the shape. The surface is still too rough to lay fiberglass on but I do a little more work to fix that issue.
I measured the angle of the exit dam and it came to 40 degrees down from the bottom of the cowl.
I plan to make this piece out of fiberglass and later attach it to the cowling with solid rivets.
Posterboard folded and notched
View inside cowling (aft looking forward)
Exterior view of exit air dam
