I purchased the FI system from Airflow Performance. As my engine has an updraft oil sump, API sent a 90-degree elbow to attach to the fuel servo. Upon the initial installation I discovered the metering portion of the servo would contact the sump if installed on top, or they would contact the cowling if I rotated the servo 180 degrees.
After talking to the folks at API, I sent the kit back to them to modify the servo by installing an elbow in the fuel outlet port, exchanging the 90-degree elbow for a 95-degree elbow, and adding some spacers, flow ring, and the alternate air box.
