Brief Description: Riveted fuel pick up tube assembly
Tonight I installed, sealed and riveted the fuel pick tube assembly. In order to torque the fitting, I needed special fitting (the name of which escapes me right now) but it has an area open so that it can be slipped over the tube and onto the nut. Once torqued I had to adjust it slightly so that the anti rotation bracket could be installed. The shop head is in the view you see in picture 2 and was a bit difficult to reach because of interference with the bracket but it turned out ok. Picture #3 shows the outboard side and you can see that there is no way fuel can get by this fitting. I was really happy the way this came out.
