Brief Description: Received inboard rib and joint plate
I received more parts from Avery today ; nylon pitot static tubing and fittings, additional clecoe pliers , drill stops, Mini micro stop c'sink cage, flush rivet set, nutplate drill jigs.
Also received new inboard rib and joint plate from Van's. Started on these two parts by smoothing edges and straitening the flanges
