Brief Description: Left wing leading edge assembly
Installed and clecoed left wing leading edge to spar. I had to buy a second crappie pull riveter to rivet the rib flanges to the spar web. The other one I had was not working very well after grinding the nose of the tool too much. Had to do this because of clearance issues between the tool and the rib. After grinding the second rivet tool down, I wrapped that area with vinyl tap so as not to damage the primer. As usual the left wing was a piece of cake compared to the right wing leading edge.
