PETER'S WEB SITE
Date:  11-22-2010
Brief Description:  Riveted top skin of right wing
Louise helped again to buck the right wing. I had some concern after a while because I was getting oil canning between ribs, but as I progressed the skin became stiffer and at the end there was no more oil canning. I left a few rib holes clecoed because the rib flange was not sitting up to the skin. I will try and fix this tomorrow by gluing the rib flange tab to the skin and leave clecoed until dry. Then I will rivet. If this works, and it should, I will remove a couple of rivets on right wings where this also occurred leaving a noticeable depression when the skin tried to pull up against the rib flange tab when riveted. Structurally ok, but not very nice to look at.
Top inboard skin almost completed
inside view
inside view
Note fishing line used to check for level
