Brief Description: Worked on top skin and wing walk doubler
Today I cut the RW wing walk doubler, clecoed and match drilled the top skins to the right wing. I also clecoed leading edge to the right wing. As usual I can get tasks done in about half the time with both wings on the stand at the same time. Not sure if I mentioned this before but because I have lots of room, I was able to have 32 inches between both wings. The cross member is a 2 x 4 lag bolted to the (4) vertical posts which are eack made using (2) 2x4 screwed to each other.
