Brief Description: Curling leading edge of right elevator
Ok last leading edge to do. This one better be perfect. Again I changed my approach. First off I edge rolled the skin, then started curling the top skin first to provide max bending room. I also this time I bent all 3 sections at one time and used two vise grips instead of pipe clamps. The bending process is easy enough, but the problem is that it is difficult to make the two skins to sit flat.
Broom stick taped to skin
Used visegrip to bend or curl the LE
Not bad but I was able to fine tune and make this better
