I decided to attempt bending the left elevator today. This time I bent each section one at a time. And used 3’4 in wood. I used a different rolling tool I bought from Avery. I find it worked better than the vise grip version. Easier to control and better results. The outer section came out almost perfect the first time around. The center section gave me a bit of trouble but not nearly as much as the rudder. In the end I was able to get the edge to lay flat with very minimal waves. Riveted LE looks much better than the rudder.
