Brief Description: Riveted stiffners to RS elevator
Started riveting stiffners to top skin. Pretty easy except that the last rivet of each stiffner at the trailing edge was a bit of a challenge to get to with the rivet gun. In a few cases, the rivet did not seat well in the dimpled skin and is a bit proud.
Riveting the stiffners to the bottom skin went a lot better except ...wouldn't you know it...the last rivet. I'll have to replace this one. I may be able to drive the others flush with the flush rivet set since they were not as bad.
