Finished drilling and countersinking both sides of the wedge. Prepared a small batch of tank sealant to test on sample parts. Boy this stuff is sticky. I don't have the right tools or scale to weigh this stuff out. I used a digital scale my wife had but the accuracy was not good enough so I'll get another one. To make sure I don't get a wave between holes, I decided to add a second angle on the top side when gluing the two skins to the wedge. I have the angle but have not drilled it yet. There is no RTV called out for rudder trailing edge stiffners. I'll check what other builders have done here.
Trailing edge wedge drilled and c'sink
Wedge installed in rudder
Looks straight to me. Should look great when done.
