PETER'S WEB SITE
Date:  11-28-2008
Number of Hours:  4.00
Brief Description:  Priming prep
Tried Alodine process on all HS parts today after scrubbing all parts with Alumiprep and rinsing with water. The non alclad parts take Alodine much better. I also found that parts that are smoothed using SB wheel do not take Alodine as well ( parts get too polished). This stuff is very toxic so rubber gloves and good filter is in order. I am doing all the priming process inside the basement just inside garage type door. Later on I placed a box fan to increase to add additional ventilation but it really is quite safe the way I am doing it. Rinsing the parts is done just outside even when it rains! Since I'm rinsing anyway, the rain helps out.
Parts drying after rinsing off Alumiprep 33
Applying Alodine 1201
Applying Alodine to HS spars
