Cleaned the workbench and started the ass'y of the HS front spar. Then I match drilled and trimmed the spar reinforcement angles HS710 and 714. It was easy to bend and check the angle. To bend the front spar, I clamped a piece of wood at the bend line and bent the spar until I had the desired angle.
