PETER'S WEB SITE
Date:  10-2-2009
Number of Hours:  3.00
Brief Description:  Leading edge and fuel tank work
Started the night by drilling the W423 joint plate screw holes to #19 with the fuel tank still clecoed to the wing.
I then drilled the RW leading edge skins except for the inboard rib and W423 joint plate which needed to be replaced. I should get the replacement rib and joint plate material next week. When I mentioned this to Steve Ashby, he said he made the same goof. That makes me feel a whole lot better knowing I'm not the only one...right! Wrong, I was still upset. I knew I should have checked progress as I was drilling but instead, I drilled all joint plate/rib holes before checking if everything was perfect. The holes wondered off the rib flange centreline and at the nose end, they were almost off the flange.
I then c'sunk the remaining tank screw holes for the #8 screws that will be used to secure the tank to the tank baffle.
I wanted to fit the tank outboard rib but in order to do that I had to first remove the tank, then remove the leading edge, and then re install the tank.
Then I reinstalled the leading edge to check that the W423 joint plate fit was good...and it was.
That's it for tonight
Left wing fuel tank
Left wing fuel tank
Leading edge ready to be disassembled.
