Brief Description: Installing and drilling W408L rib to leading edge
Positioned and back drilled W408L leading edge rib to spar web. I then positioned the W423 joint plate between skin and rib. I made sure that joint plate and rib was correctly positioned before drilling through joint plate and rib. End result was perfect.
