Brief Description: Completed riveting ribs to front and rear spar
I completed riveting the ribs to front spar and replaced 5 rivets that were out of spec. I then clecoed rear spar and made sure to identify the holes that would not be riveted. I riveted all rear spar wit hand squeezer.
I had no problems riveting wing walk ribs. I installed these one at a time and riveted starting with 4th from root, then 3rd and so on.
I started to build the wing jig
Ordered 300 additional clecoes from Avery
Riveting rear spar
Wing walk ribs...note the three holes that can be used to pass tubing for pitot and AOA
