Continued to c'sink front spar web and completed all the tank attached nutplate rivet holes. I then c'sunk the for two K1000-4 for nutplates for attachement of vertical bar spacers in center section. I used a light tak tape to cover the joint so that aluminum shavings did not get trapped between parts.
Painters tape used to cover the spar webs to avoid aluminum shavings between parts
