I made the decision to go all out and prime all parts using AKZO two part epoxy. I knew this would be very time consuming so I planned to make the process as easy as possible. First, for now at least I have all the AKZO equipment and solutions on one dedicated table. I use large syringes to measure equal parts of Part A & B. From past experience I knew that cleaning the spray gun would be a pain so I tried to make this as easy as possible by using desposible plastic containers and pyrex jars. I also purchased several manual fluid pumps as shown below to use to draw Aceton and MEK. Works great....no mess. I made a workbench to clean and prime all parts. It is made of 2x4's and heavy duty wire mesh.
HVLP from Harbor Frieght and rest of primer system
