After completing deburring the HS, I tried a different method to support the DRDT-2. I moved the 2 workbenches apart and placed the DRDT-2 between the benches and supported it so that the dimple plate was level with the top of the work bench...... works great.
DRDT-2 supported between benches
Supports are easily removed when DRDT-2 is not needed
