PETER'S WEB SITE
Date:  9-23-2008
Number of Hours:  1.80
Brief Description:  Dimpled right side HS skins
Before dimpling, I removed about 1.5 inch strips of the proctective plastic using soldering iron.I later found that this process worked better with higher wattage one. I made sure to round the edges of the copper tip so that the skins would not be scratched. Clecoed the left HS skin to skeleton.
