PETER'S WEB SITE
Date:  9-15-2008
Brief Description:  HS - Front spar
Cleaned the workbench and started the ass'y of the HS front spar. Then I match drilled and trimmed the spar reinforcement angles HS710 and 714. It was easy to bend and check the angle. To bend the front spar, I clamped a piece of wood at the bend line and bent the spar until I had the desired angle.
That's me filing near relief of HS front spar
HS front spar ready for bending
Radiused wood block clamped
