Brief Description: Fabricated the aileron to control stick pushrods
Cut 2 the pushrod tube to length marked the 6 equidistant holes around each end making sure to keep correct edge distance and setup drill press to drill all 25 holes. Inserted the threaded rod ends to the given position on the drawings, and match drilled the rivet holes through the tube and rod ends. The rod ends fit very tight in the tube but just to be sure it did not move, I wrapped masking tape around the circumference. After deburring the holes, I inserted and pulled the required MSP-4 rivets.
Set-up to drill pushrods
Used a camera tripod at the other end to adjust level
