Brief Description: Started the F705 rear spar bulkhead
I assembled all the bulkhead parts on the table.
Located, clamped and drilled F705B center section bar and F605C spar end doublers to final size.
Drilled then reamed 3/16dia holes in seat belt anchors. Once the first anchor was in correct position I clamped wooden stops for correct alignment of the other anchors.
Fabricated the two F705H spacers that will be placed between end of rear spar and rear spar doublers.
F705 bulhead parts ready for assembly and match drill
Drilling rear spar , doublers and spacers to lower bulkhead
