PETER'S WEB SITE
Date:  3-23-2010
Number of Hours:  1.00
Brief Description:  Bent fuel sender
I order to make a good bend, I made a radiused bending block out of scrap piece of aluminum.. I then using tube bending instructions as a guide, I calculated the bend lines and practiced on some welding wire I had to verify the result. Once satisfied that calculation method was correct, I maked the fuel sender wire and maded the bends as required. The result was as close to perfect as possible.
Sender rod ready to be bent over radiused block
Assembly in
Assembly in "low fuel" position
You can amost see bend line mark
