Brief Description: Riveting ribs of right wing to front spar
Tonight, I riveted ribs to front spar. This time I mounted the clecoed wing assembly on the wing stand to rivet ribs. This turned out to be a better position compared to the method I used for the left wing.. I also followed the recommendation made in the manual to place the manufactured head on the rib flange. Easy to do and great results. Again the trick in riveting is to concentrate on the rivet gun position and just hold the bucking bar steady with light pressure.
