Steps 1 thru 4 are easy. I was not excatly sure which end of the trim wire goes where. The instructions state the end with the red heat shrink, mine has white heat shrink on it and pins on the other side. So I put the heat shrink at the bushing.
I did findout I made a mistake on page 10-07 step 3, I riveted all the holes on the side of side skins R1281L & R. the instructions state not to do it as the next side skin falls over the top rivet hole of R1281. That rivet will link both together. So I drilled the rivet out.
the picture of step 5 shows a different date but that is because the picture I took on 6/1 was not good.
