Continuing with this step I started pluggin the CS4-4 rivets in the holes and discovered that I did not have enough rivets. When ever you have part that does not fit or don't have enough of a certain part you have done something wrong. Using the great Vansairforce forum I found out quickly where I had made the mistake. On page 9-03 step it shows to only rivet the CS4-4 rivets in 2 places and I did all the center holes. So I drilled them out which went well and ordered some more CS4-4 rivets from Vans.
The third picture is almost a month later. It is hard to find the time in regular life with other hobbies and trying to fly in the winter time.
