I received the new Cleaveland main squeezer and squeezed the rivets for the nut plates of the upper spar cap. What a difference, somuch easier to do.
Also started working on theAvery rivet puller, I noticed yesterday that I had to pull the trigger twice to get to put and snap off the mandrel. I read a lot threads on VAF and the user manual, I readjusted the tool, put a different tip on and it worked much better. Only thing I could not get done was to check the oil, I could not losen the the bottom nut.
Not that the puller was working better I wanted to improve the blind rivets I had pulled before. So I drilled them out and put new ones in and they look better.
Started on Page 6-05, I radiused the front corner, tried to flute but have not figured it out completely, have to continue with this tomorrow.
