Peters Web Site
Date:  6-16-2013
Number of Hours:  0.50
Manual Reference:  10-09
Brief Description:  10-09 Step 1
Step 1 installing the ststic ports, there are no real instructions, meaning a step by step with pictures. I read the limited instructions and builders logs and I will share the steps with you.
- Place the ports in the holes and use your rivet puller to pull the rivets.
- I found out the the mandrel of the port was thicker than the reguler LP4-3 and the mandrel did not
fit in the hole, see picture 3. I had to put a different size piece on the front.
- Pull the rivet and the mandrel will come out but the head is still in the static port.
- Reading a builders log it described the method of drilling as hole in a piece of wood and holding it
behind the skin while driving out the inner piece.
- I used the mandrel of a regular rivets and pucnhed the inner part out while my wife was holding
the piece of wood.
