I found a couple holes on the firewall that were missing rivets .... now done.
There were nine holes down each side of the fuselage still requiring rivets .... now done.
I started installing the brake lines, from the pedals to the park brake valve. I could fit them to the pedals okay, but I need to buy a couple straight fittings to install at the park brake valve.
I found two holes on the firewall that still required rivets. One is shown here
Finished the last few rivets holding the side skins to the longerons
Installed fittings and brake lines to the brake pedals
