Peters Web Site
Date: 11-11-2017
Number of Hours: 4.00
Manual Reference: 9225501-LOG-05.002
Brief Description: 1: Firewall Parts
I'm pretty well done with the wings for now, so today I turned my attention to the fuselage.
After stacking the wings away in their cradle, and giving the workshop a bit of a clean up, I started by making up a few of the parts that attach to the firewall. The brake line bracket was pretty straight forward as it was already pre-made. I just needed to match drill it to the firewall, then deburr, smooth and prime, ready to rivet in place tomorrow.
There is a doubler plate required for mounting of the fuel pump, which I needed to make from scratch. The nutplates are a little confusing on this plate as they're actually mounted on the forward side of the firewall, whereas the doubler plate is on the back side. Anyway, once I got my head around that then I match drilled, deburred, smoothed and primed. Another piece to rivet in place tomorrow.
Next up I match drilled the firewall recess box. Apparently this is required to allow room for the prop governor (if I have one) and oil filter. Although I've got it all ready to rivet into place, the instructions recommend leaving it out for now to allow easier access to other parts.
Making up the brake line firewall mount
The fuel pump firewall doubler, made as per drawings
Match drilling the firewall recess box
