I decided to focus some time on the tail section of the plane today, and as much as I love looking at the horizontal and vertical stabilisers all bolted together, I needed to dissassemble most of it so I could create some access for myself to the "inner workings".
With the vertical stabiliser unbolted I could finally finish off the pitch trim motor wiring properly. I fitted several nutplates to the aft deck to hold the wiring in place, and then terminated the motor cable, hopefully for the last time.
It's now much more secure, and looks much neater.
Trim motor cables properly secured to the rear stabiliser deck
All wiring is labelled with heatshrink wire markers
