To make my concealed hinge work on the map box door I needed to cut away a portion of the box bottom flange, which unfortunately resulted in a loss of rigidity.
To overcome this I made up a simple stiffener from a scrap of aluminium angle and riveted it across the bottom of the box.
Solved the problem.
Making up a stiffener for the bottom of the map box
