Peters Web Site
Date:  3-2-2019
Number of Hours:  2.50
Manual Reference:  9225501-LOG-11.036
Brief Description:  1: Nav/Strobe Switch Wiring
I had a small dilemna with how to go about configuring my nav/strobe light switch. I bought a 3-position switch (ON-OFF-ON) for this, however could only get a single pole.
I want the switch to operate such that in one ON position just the strobe lights are on, and in the other ON position both the strobe and nav lights are on. Of course the centre OFF position is off.
With a double pole switch this is very simple to configure, however with a single pole then I had to use a signal diode in circuit as shown in my first picture below. I haven't been able to test this yet, so it's still theory only.
I soldered the diode in place in the wiring loom and covered in heatshrink tubing.
Use of a signal diode to allow Strobe only, or Strobe plus Nav, switching
I soldered the diode into the wiring loom
