Tonight after work I cut out the hole in the instrument panel for my Dynon Knob Panel. This little instrument provides easy access to three often used controls, those being barometric pressure (QNH), as well as altitude and heading setpoints, without the need to go through Skyview menu selections.
I also spent a little time finishing off an idea I've had for an under-panel mounting bracket for the Alpha Systems angle-of-attack switch panel. Access to this tiny little panel is only needed when configuring the AoA system, and I'm thinking of making up some sort of sliding bracket such that it can be slid away under the panel when not required, and slid forward for access when needed. This is still a work in progress, so we'll see where I end up in a week or so.
