Worked on the underside of the elevator tips this morning.
Sanding, sanding, sanding.
I started with 120 grit, then went to 180 grit. When the surface felt done then I applied a coat of primer ..... that's when you see all the imperfections.
Sanding back the fibreglass resin that was applied yesterday
Now with a coat of primer
Bottom side of both elevator tips done ... for now
