Next up today I assembled the trim tab servo mounting assembly. This was pretty straight forward, with the only problem arising when I tried to fit the completed assembly into the elevator. The opening didn't seem big enough. I eventually worked out a way of wriggling the thing in such a manner that I was able to squeeze it in. Seems odd that the opening doesn't seem quite right. I wouldn't be suprised if the servo dimensions have changed slightly over the years, and Vans have done nothing about the size of the opening. Just my thought. At the end of the day, it doesn't matter as the assembly does fit.......just.
