Peters Web Site
Date:  4-24-2017
Manual Reference:  9225501-LOG-03.081
Brief Description:  2: Trim Tab Jigs and Tools
Much of today was spent making up the various little tools and jigs necessary to build the trim tab.
First up I built a simple bending brake from a couple 1m lengths of 190x19mm pine. The instructions say to use 8"x2" (190x45), however this is very expensive here in Roxby, and besides, I didn't think the added mass was actually necessary for bending the little trim tab skin (and I was proved right later in the day). I lined my brake with felt to make sure there were no marks left on the skin surface. I also added a simple handle to make using it easier.
Next I made up a couple simple wooden clamps so that I could easily, and accurately, bend the trim tab end pieces over, exactly as advised in the instructions. This worked quite well.
And lastly, I also made up a couple clothes peg style clamping blocks, by following the template on the plans. These will be used to apply pressure over the trim tab stiffeners as the tank sealant sets.
Bending brake, for bending the trim tab skin to final shape
Wood clamps, to help bend the trim tab ends over
Trim tab clamps, for applying pressure to the stiffeners as the tank sealant sets
