Brief Description: 2: Assembling the Right Elevator
This afternoon I got started on assembling the right elevator. First up, I riveted the nut plate stiffeners onto the spar, and then I riveted the right counterbalance arm together.
There's quite a few rivets holding the counterbalance arm skin piece in place, and I want these to look as unobtrusive as possible (a whole heap of rivets in a small space always looks like a patch job to me), so I spent some time going over all the dimpled rivet holes in the skin piece with the countersink cage, just taking a tiny bit off so the rivet heads sit perfectly flat.
After riveting the assembly together I touched up any bucking bar scratches I inadvertently created.
It's nudging 40C now, so time to go and cool off.
That's a nice lot of rivets holding on of the elevator attachment points
Holding the right counterbalance assembly down to rivet on the small skin piece
Right elevator counterbalance arm assembled, and all scratch marks touched up.
